TwinTurbo.NET: Nissan 300ZX forum - No the engine was removed to put in new harness
Jon300zx2+2TT
on September 01, 2012 at 4:18 PM
More background info, please.
posted by SactoTodd
on September 01, 2012 at 03:01 PM
But Once the engine was out all the above was done.
Engine is back in turns over but doesnt fire up.
Pulled the plugs and they were all gummed up crappy bosch side spark, Going to put the NGKs back in and see what happens
Car wont idle or rev.
Jon300zx2+2TT
14:07:05 09/01/12
Consider replacing the fuel filter. how long's it been? (n/m)
CoHPhasor
14:09:33 09/01/12
Re: Consider replacing the fuel filter. how long's it been?
Jon300zx2+2TT
14:10:55 09/01/12
Engine was out? CONFIRM coil pack routing
CoHPhasor
01:20:14 09/02/12
Even worse,... the ground points for the PTU
CoHPhasor
01:23:18 09/02/12
SactoTodd
15:01:22 09/01/12
No the engine was removed to put in new harness -
Jon300zx2+2TT
16:18:16 09/01/12
So the motor was out? Fuel lines crossed?
SilverTwin(OH)
16:53:34 09/01/12
No fuel lines arent crossed. Right now I have the injection
Jon300zx2+2TT
17:06:33 09/01/12
Have you checked the TPS. What is your fuel pressure. (n/m)
michaell32 (FL)
15:19:52 09/01/12
Fuel pressure 2 bar.
Jon300zx2+2TT
16:14:43 09/01/12
I found this in search "test tps"
Gordo 93TT Daytona
21:39:14 09/01/12
does it even start or just crank?
nissan300zxwork
18:27:43 09/01/12
Vacuum leak (n/m)
AHos(Chicago)
20:56:13 09/01/12
If you checked for spark and fuel and its good, then check
CmyZ
20:58:07 09/01/12
vacuum leak sounds like a big possibility
Drk93TT
09:24:09 09/02/12
